Car wont start!!!
awbr
36
Feb 15, 2005
west side, New York
I have a 1996 Eagle Talon tsi awd. I bought it for a 1,000 with a crap load of parts. I ended up putting in a 7 bolt back in it. ( was going to do the 6 bolt swap) , I got it all together and tried to start it. All it would do is turn over. But no start. So I ended up getting a (CPS) and still wount't start. So we checked all the wires in the harness, nothing. Then changed the (cas) still wouldnt start. changed the coil,ignitor still no start.Tried to start with diff ecu , and nothing. So does any body have any ideas on what I should do?? Gets no spark, its getting fuel cause, you can hear the fuel pump. I'm lost , any help would be great thanks
Just because you hear the fuel pump priming doesn't mean your rail and injectors are working properly.
Check the timing belt, could be off a few degrees and making everything not work.
Make sure the battery has enough power to start the car.
If you were going to do the 6 bolt swap did u make sure you didn't mix the coil packs and recheck the order of the plug wires just in case.
We pulled one plug to check for spark and thier was none. I bought a new battery, and I charge it to make sure it fully charged. I have 3 coil packs the 1g is different than the 2g, soI dont use that one at all. But I have 2g coils, we checked the and the are 12.6 ohms on each coil.
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
  • For sale 2g sunroof shade cover
    I have 5 sets of these. They are freshly re upholstered. The material I used was black suede. I...
    • Jose gonzalez
  • Wanted 2g ISO Rear Pass EDM Tail light
    Looking for only a passenger rear EDM tail light for my 2g. Please lmk if you have one lying...
    • Gabriel Pena
  • Wanted 4G63 ISO built short block
    Looking for either a 7 bolt split thrust or 6 bolt
    • Gabriel Pena
