transfer case
jjrad27
Jul 19, 2007
saint joseph, Missouri
Hello i have a 1992 eagle talon awd and the transfer case locked up i cant get a new one until friday will it hurt to drive my car with the front axles hooked up only?
When the car is AWD you cannot drive the car without the drive shaft unless your transfer case is welded. If you just unhooked the drive shaft it will freewheel. Be like having no clutch in the car or like taking the axles out of a FWD car.
edit: Done alittle search for you.
http://www.dsmtuners.com/forums/showthread.php?t=265477&highlight=driveshaft
hope this helps your question.
thank u for the answer and the research thread ill just wait isnt worth screwing up my trannny
