iamtall77
- 185
- 1
- Oct 9, 2002
Las Vegas,
Nevada
I've read the few threads in this forum that deal with this issue. This is on my 95 TSi AWD. In short, my coolant is brown and foaming when the engine is warm. I don't seem to be losing any oil. There is no coolant in the oil and the compression on the cylinders is even across the board. (150psi @ 11.8psi atmosphere) My coolant overflow bottle had, what appeared to be, mud at the bottom of it when I flushed the system. I now have over 5 gallons of brown fluid and it is still getting discolored when I add new water to the system. What the heck is going on? I can't think of anything other than maybe a bad headgasket that seems to only leak between coolant and oil passages. Or that my oil cooler (stock) somehow is getting oil in the coolant, but not coolant in the oil. ANY ideas?
We'll go from there . . .
