Heavy-D
- 86
- 4
- Aug 7, 2004
New Haven,
Connecticut
Well first I had an overheating issue yeserday that I'll describe afterward, so I drained and flushed my radiator, then refilled it. Now the big problem I just was after said drain/flush/refill of coolant. I was driving in a town (pretty light on throttle, almost no boost) and about 3 minutes later, i peeked down at my dash and saw my temp was nearing red. I pulled over and turned off the car with 30 seconds, and the dial was touching red now. I could hear the coolant boiling in the overflow bottle after I turned the engine off. Some vapor or smoke was coming off the bottle and engine too. I popped the hood and could hear the coolant bubbling visciously. Did I blow a head gasket? Is it time for a new thermostat?
Now my overheating problems yesterday was limited to highway driving. Without any problems up to this point, it started overheating yesterday. First the factory temp. indicator was getting high so I got off the highway, bought some coolant, let the car cool off and put a small amount in. Got back on the highway and temps started to go up so I turned my heat on full blast. temps went to slightly below halfway, but now my turbo timer, which reads from a different location just kept climbing.
So overview, dash indicator stayed normal while turbo timers reading kept climbing (got up to 53*C so I shut the car down again). Now when I got off the highway the car either stayed the same temp on the turbo timer or went down. It seemed to be that 60 mph was where if I went above hotter, and went slower, got cooler.
