Ippkiss
- Dec 25, 2006
Warren,
Utah
Ok, I'm a little stumped on project 1300$ whore
Car ran decent when I bought it. Idle surge, but it ran. Car had massive coolant leak that turned into blown head gasket. Car ran well enough to drive it 60 miles home
Car is 1991 GSX a/t. Car supposedly has 450's & M/T ecu.
while the head was off I did:
Replaced head gasket
replaced intake manifold gasket (thermal insulation gasket)
replaced tb elbow gasket
replaced or deleted vac lines
replaced turbo (e3 16g)
ported turbo, 02 housing & exhaust maini
all new gaskets on exhaust side
upgraded grounds from cylinder block & head, frame rail to battery
1g M/T cams
new timing belt, water pump, balance shaft belts, tensioner, pulleys, & crank damper
arp head studs
fixed coolant temp sensor connection (car has a hacked to #### wiring harness)
head was broken down to bare casting and cleaned because of metal shavings found in it.
Car starts, idles, will free rev but you can tell it has a miss to it. Tried to adjust base timing down, but timing seemed very erratic even with the proper pin grounded. Could have been a bad ground on this.
When put in gear car revs to aprox 1400-1500 rpms, and stops.
Idle vac is very low, at around 13-14", Seems like timing belt could be off.
Compression is a steady 140 psi across the board maybe up down 2-3 psi. I'm at 4800 ft ASL so these seem like fine numbers to me. Would having the timing belt off cause this while still allowing good comp #'s?
No o2 sensor on the car right now, but it seemed to be doing ok with out one before. The harness has been hacked off, and I haven't quite figured out which wires go where yet.
Supposedly car had brand new NGK wires & plugs just before I got it, I'm about to replace plugs just to see if it does anything. Old plugs came out looking rich, lots of black soot. Put in brand new NGK's & did not change anything.
Car has been leak tested and most of the vac leaks are gone, the few small ones (very small leak on biss screw, tb shaft also needs new o rings) don't seem to be enough to piss of the car this much.
Car did have CEL for no coolant temp sensor connected, but I fixed that part of the wiring. Logger shows air flow from the MAS, so I believe it is plugged in & working.
I am getting some decent lifter tick, maybe a lifter has gone bad.
1g M/T cams
arp head studs
