EclipseTrbo420A
- 3,427
- 39
- Jan 23, 2004
WhiteOak/PGH,
Pennsylvania
Well the gods at autozone told me awhile back my gas cap was the culprit of a CEL I just cant lose. My spuid fault for believing them. Well I went back today and asked to run the diagnostic my self and I came back with P0446 Evap Purge Solenoid Circuit Malfunction.
Finally, narrowed it down to this thing! So the tests begin I took off the nasty connectors cut and spliced fresh connections...nothing changed.
I came in the house and bench tested it, open'd fine with power from my battery charger and sealed perfect while off. Then confused it worked, I tested the resistance like my manual said and it came back perfect needed to be between 35 and 44 and I made 38.2ish. So Does that mean the soleniod is good?
I put it on the car hooked it up and started it, went back under the hood and felt it for the rapid clicking people complain about, but I didnt get that It just clicked maybe 2 times a second like Click, Click Click, Click <--I know that means nothing unless you heard it.
So my other question is Should this be clicking unbelievebly fast like I read others are or should it be doing what I said? OR should it just open when the car is on and close when the car is off? I put a piece of vac line on it and sucked, it only let me pull in, in montion with the clicks...obviously doing its job. Anythoughts...this would be easier if I just came back out of spec or didnt even open at all, but it all checks out.
One more question...can I switch my EVAP and EGR solenoids just to test my theory? Essentialy they are the same thing and if the EGR Is working correctly the code should then change over for that if I can the EVAP one in its place. Thanks guys, sorry if that was alot.
(refer to post #6 in your original thread regarding this issue). Sorry, I just needed my daily affirmation
all came back as it should.... You wouldnt happen to want to see how your solenoid functions for me would you ? LIke the clicking and all that. I think im going to run out there and switch the EGR for the EVAP one and see if the code changes or stays the same.
