bouncy 2gen eclipse?? help?
DSM_JP
Jan 25, 2007
Billings, Montana
well my 2nd gen 97 eclipse RS non-turbo FWD has Tenzo lowering springs adn stil has stock rear struts but i replaced the fornt 2 with sensitrac's from napa, and now it boucnes a ton, but i am sick of scrapping my bumper, would stock springs act well with the sensitracs?? and does anyone ahve stock springs for sale?? well call me if you do if you know another way to fix this problem thanks JP (406) 861-5211 i think i want stokc springs so call me if you have them
Your shocks/struts can't handle the springs. The sensitrac are made for a soft ride until they compress a fair bit then they stiffen up. This could be the reason for the bouncy ride. GR2 struts are the lowest you want to use with a lowering spring. If you want the lowered look and performance then I would get new struts front and back. The GR2 are the cheapest then AGX or Koni both adjustable are a bit more. I use to have Eibach Pro Kit springs and GR2 on my 1G AWD and they were great.
