AWDPetmitsu
- 1,054
- 15
- Jan 26, 2003
Pennsylvania
My dash battery and coolant level lights don't light up when I turn the key to the ON position, engine off. The headlights and all interior lights were dim when it was running earlier. It wouldn't start like the battery is dead but it'll start if you let it sit for awhile. Then it'll sputter and die after a couple of minutes running.
The alternator and battery were just replaced 2 months ago. I know either can be defective even when replaced. The 80 amp alternator fuse looks good. I've yet to check the fusible link from the alternator to the starter and haven't checked battery voltage nor charging voltage (meter is at workplace.)
What am I missing? Mainly, why aren't my battery and coolant level lights lighting up with the key in the ON position, with the engine off?
__________________
__________________
