bpe121212
- 59
- 2
- Apr 24, 2006
Lynchburg,
Virginia
Hey guys, I am in need of some help, Please!
I have recently added a Garrett BB 50 trim, Greddy RS BOV, Tial external wategate, and ETS FMIC and car now Stalls on deceleration and idles erratically. The AFR is extremely erratic at idle and seems to be jumping from 13.5/1 - 17.2/1. The car ran just fine (a little rich under load - 10.5/1) before New Turbo and FMIC install, even though I had already replaced the stock injectors with 750's and run with stock T-28 turbo and SMIC. I did a Boost leak test and found a leak through the throttle body tube going to the check valve of the evaporative emission canister. Is this OK? When I checked the evaporative Emission can while car was ruining I could feel air coming out of the exit port at the top marked AIR (nothing was connected to this port, it was vented to atmosphere). I also noticed a slight leek from the compressor housing where it meets the turbine plate (I guess this is expected since there is only machined aluminum meeting machined aluminum). Even though these leaks need to be adressed, the car ran just fine with these leaks when using the stock intercooler, turbo and BOV.
Thanks in advance for your help with this!
