sakrafice
- 217
- 1
- May 28, 2003
Sumpter,
Michigan
Well my turbo, if it isnt bad seems to spool up like nothing, i dont have a boostguage hooked up because i lossed the line and awaiting a new one to come.
But the car naturally runs like shit since i did the swap (6bolt in 2g with 2g head), but the car at one point in time you could actually feel the car boosting (not very well and building boost right away which seemed odd), now it just goes and u here it whining and not pulling at all, there is no shaft play on the turbo, i have my MBC hooked up from wastegate to controller, and the stock tube that goes onto the turbo i used one of those lines for the other conection instead of teeing off the intake. Since i have no nipple on my hard piping going to innercooler
Other factors could be bad 02 or wired in wrong.. still havent done injector swap cause i cant get the pins out. I have nothing to help me tell me whats wrong with the car. Im to the point that imma sell this thing cause all it does is eat up money and still same things.
Car also will idle high, and if i adjust biss, car will wanna die. I play with the CAS but i have no clue what im doing and dont have no friends that know anything about cars. I know the car is getting knock, car spits, sputters, and just over doesnt wanna go unless u have it i guess creating boost then it runs okay but dont pull at all.
Im also to the point that i would pay a fellow local dsmer to come over and help me fix these problems i really want to keep this car but i can only take so much dissapointment. thanks.
