Fayt
- 515
- 15
- Mar 26, 2005
Cleveland,
Ohio
So, just put my evo 3gt in. Drove it around for about 500 miles, and now I can't figure this out. I smoke under acceleration, from about 4500 on IF I'm boosting. Under normal conditions I don't smoke.
Here's the info...
-New NGK6ES plugs
-New coilpack
-OLD Plug wires/stock from 6bolt
-New Evo 3gt, primed properly after install.
-No oil in downpipe at all.
-Small amounts of oil in LICP, but barely covers the inside.
-No boost leaks from LICP on. Haven't checked from the turbo inlet because its a really tight fit, so I'll see if I can get a longer connector.
-Leaking a very small amount of oil, but I'm not sure where.
-Oil was replaced less than 500 miles ago.
-Once it starts smoking, it'll keep smoking @ idle and under boost occasionally. Normal non-boosting driving is smoke free.
-New rear O2 sensor.
-Only getting about 14 MPG city even when not boosting.
I haven't done a compression test or anything yet, just looking for suggestions. Could it be my spark plug wires maybe? I have MSD 8.5's coming Tuesday. Bad injectors? I have a CEL that I'm going to figure out on my way home. Any ideas?
Here's the info...
-New NGK6ES plugs
-New coilpack
