dsmoverboosted
- 217
- Feb 26, 2006
Winnipeg,
I am going to blow my mind if I don't get this problem fixed soon. I recently got a head rebuild done and installed the head myself afterwards. Before the head rebuild I had a problem with the car "poping" at idle but I could drive it fine till 5500rpm (I would hit fuel cut because of bad guides).
So after I finished the reinstall the car ran pretty good but I now couldent go wot passed 5000 rpm because it would sputter and backfire (defenently different than before). Now that wasent too bad because atleast I could still drive it normally but yesterday I went to the store and it drove normal, when I came out and drove off the car got worse somehow. Now I cant accelerate at all without poping, sputtering and backfiring so bad. I got black smoke coming out of the tailpipe now.
So today I had to see my parents for fathersday and its a good 20 minute highway drive there. halfway down the car fixed itself. I couldent beleave it, I pulled over to the side and took off through all gears boosting in each gear and it was the same as it was before i went to the store. I got there turned off the car and when I went to leave it was doing the same shit again sputtering and backfiring no matter how i accelerated.
This is driving me nuts!!
So far I have done the following to try to fix the problem..
New plugs bpr6es's gapped to .28
New wires
Swapped coilpacks with my parts car with no change
Swapped transistors with my parts car with no change
Swapped cas with my parts car with no change
Did 3 boost tests with only my tb shaft seal leaking
checked timing with a timing gun but it was at 5 deg
Also before I went to the store my stock gauge was pretty much dead on with my aftermarket one but now my stock guage will bounce around and hit as high as one bar when my aftermarket one hits 1psi. I also notice the only way for me to accel at all is to keep the 2 gauges as close as possible together.
Also I was playing around with the coilpack hearness and when i push the harness together with a good force the engine revs up. Is that suppose to happen?
I need some ideas. The big thig is getting my car back to running like it did before I went to the store so I can atleast drive it without holding up traffic like some asshole.
Thanks Axe
New wires
Thanks Axe
) What I am hoping to do is get a local dsmer with a good running car (as rare as it is
) and "try on" some of his ignition parts to find out what I need.
. I will be getting a new ecu soon and I will be rolling again
