JLangevin
- 155
- 1
- Oct 14, 2005
Rialto,
California
I had some kind of tranny failure the other day, just not sure what it could be. Im going to take it to a trusted transmission tech on monday, but wanted to run my problem by you guys first...
The other day, my car was getting a bit of resistance when stopping, so I pulled over to investigate... when I pulled over, the tranny was making a very loud buzzing noise in R, N, D, 2, 1 but not in Park... I checked the fluid level with the engine idling and full temp, the fluid didnt even register on the dip. When I went back in the car and put it into 1st to pull into a parking lot, the car would not go into any gear... I turned off the car and called a buddy. After sitting for about 5 min, I started it again and it went into gear fine... and there was no buzzing. After a mile or so, it acted like it was taking itself out of gear. I pulled into an Autozone and had them tell me the reccomended ATF... they told me it was ATF +3 but reccomended Diamond Fluids which they didnt have. I got 5 quarts and after all 5, the dipstick showed full.
The tranny continued to do its problem. When cold, the car goes into gear and drives fine, but after a few min, it starts to have a loud electrical buzzing noise and will gradually start to not go into gear.
The car has been sitting since monday. I just started it again and it buzzed from the begining but went into gear fine. I just let the car idle in Park for a few min to cycle the engine since its been sitting. The tranny is full and there isnt a single drip on the driveway. I dont understand where the fluid went. It never smoked, and has only been driven around town, no racing... Can anyone tell me what may be going on? I want to be somewhat informed before taking it to the transmission shop.
Car: 1995 GST
Trans: FWD Auto
Miles: 146,000
Thanks in advance everyone! Im needing your input.
Car: 1995 GST
Trans: FWD Auto
Miles: 146,000
Stand on a spare tire so you dont break your back. They have cherry pickers if it has to come from the top. There are always plenty of screw jacks in car trunks if you have to jack the engine or tranny up while removing mounts.
