tatersail
- 34
- Feb 23, 2006
Cape Cod,
Massachusetts
Earlier today the clutch pedal stuck to the floor. I blead the clutch for over a half an hour ensuring that there was no air pockets in the line. The clutch was sticking halfway in after pushed and would then pop out the rest of the way. After bleeding the clutch the pedal felt fine but shortly after driving a mile the pedal stuck to the floor again and i was unable to get the car into gear. I pried it from the floor and pumped it again and made it another mile down the road but it started getting sucked to the floor. Eventually it stopped going into gear again. I pried it from the floor and began to push it in but it was sucked to the floor with zero resistance. The flow control unit in the clutch line was bypassed by the previous owner with a ss line. I checked for leaks but was unable to see any. The clutch worked fine the past week, today was the first of the problems. What should i do or check to make sure what it is. Should i just replace the slave cylinder? Pressure bleed isnt required correct, vfaq doesnt mention it. Any help is appreciated, thanks.
