sepulchral
- 61
- 2
- Dec 9, 2005
midlo,
Virginia
here r my questions, please help
1) Will rotating the crank or cam gears cause pistons to bend valves without adjusting valve train? Because i did that and i'm hoping i didnt F* anything up
2) My motor was rebuilt by some dude who put aftermarket camshafts (Comp Cams #2) and each one of my cam gears has two marks, he colored one mark on each cam gears yellow, and when i align them, the cam gears will allign perfectly yet the dowel pins will point down (diagonally).
When i try to allign the cam gears with the dowel pins straight up the notches won't want to align perfectly.. they are about a tooth off and when i try to align them perfectly the cam gear just goes back to the way it was, about a tooth off. I think its the exhaust side that doesnt want to stay.. What should the lobes on the cam gears look like with them set at TDC??
3) do i need to do anything to the CAS cam angle sensor to retime the motor?? where do i connect a timing gun to time the motor
