Eclipse90GSX
- 149
- 1
- Oct 13, 2002
Arlington,
Texas
okay guys, so today i was driving around and at a stop light i glanced at my rearview mirror and i saw smoke being blown away from my tail pipe. Well i went back home, got out n smelt it and it smells like oil/gas. its blue...i think...because it doesnt smell like coolant. its blue/white its hard to say. THe smoke is only visible at idle and on throttle, it goes away upon deceleration or when the rpms drop.
well i know i am burning oil at this point, but my question is other than the turbo, valve seals and possibly piston rings where else can i burn oil? But i wasn't boosting and i was only running 10psi...but i guess the turbo may start leaking oil as long as the seals are bad, and you don;t have to be on it...
how can i check the turbo? can i remove the LICP and see if there is oil coated on it? shaft play? i can check if its the piston rings by running a compression test on it right?
i am hoping its the turbo cause then i can plug and play another 14b because this is my daily and i am in a hurry. oh well, any response or feedback from you guys would be awesome.
thanks
thanks
