fuel problem???
fredom dsm
328
49
Jan 31, 2006
Denton, Texas
hi guys, hopefully somebody can give me a hand here, I have 97 gst, with just a few mods like N1 apexi down pipe and exhaust, profec b, greedy bov, greddy intercooler pipes, KnN air filter, turbo timer and boost and oil pressure gauge, my problem is that when I hit the gas at around 8 to 10psi my car starts studdering, it goes up to 11 or 12 psi but not like it should, If I want to launch it from a red light more than likely any honda is going to smoke me, I changed the plug wires to 10mm magnacore and nothing, I even changed the the coil pack and no change at all, that is not fuel cut right? I havent done anything to my fuel system, you think is a fuel problem? I wanted to wait untill I got a hold of a bigger turbo to do it all at once pump, injectors, afc, and turbo, you guys think I need the fuel pump now? please let me know!!!!
thanks for all the help
rigo
Spark plugs: NGK BPR6ES gapped at .028" (or Autolite 63's.... andy....;))
Boost leak test
Fuel filter
Fix those and post back.
