blkGSTspider
- 124
- Jun 27, 2005
northridge,
California
i have 99 eclipse gst.
i was going to go car wash and i started the engine, i notice strange shake when the car started and RPM was kanna ab normal.
when you start the engine, you RPM goes little up and down to idle. but my car, RPM goes up to about 700 slowly with shaking not smoothly. i just thought that i have change my starter soon cuz my starter is not in good condition. i started go and car was little shaking on first gear in parking lot. i pushed clutch to put in second gear and car died and i start the engine and died right away. i waited about a minute and i started car again and RPM went up and down between 400-700.
anyways i parked car and died again. and now i got check engine light is on. i reset the car by pulling off +wire from battery. i started the car again car looked normal again but it started with same shaking and abnormal RPM but the idle was fine. i tried to go again and car died and check engine light is on too.
the car was fine like 1 hour ago when i went out to buy something to eat, on the way home, where was some annoying car (tail gating) and i pushed car little hard. is this could cause the problem?
i went up to only about 6000RPM
is this could be the battery? my battery is not in good condition either but i don't think is the battery??
my BOV is not recircuitlated but never had problem like abnormal RPM or stall.
please give me some advise
thank you
hm, after 30 min i tried to go again and idle was fine, so i made to the parking lot exit and i push the gas to 3000 RPM on first gear and when turbo kicks in car shakes back and forth. i made U turn and i head to parking lot right before i enter the parking lot car stalled.
does bad ISC could make that back and forth shaking during the car is running?
now car stalls right after engine started. i don't see anything is disconnected.
thank you
