intake vacuum
2gtalontsiawd
Dec 26, 2005
fresno, California
hi again
--I was just checking on the turbocharger and the intake hose that had the biggest hole was covered up with a bolt. One of the vacuum lines was not connected and im missing the stock boost sensor.
---where do the three vacuum lines from the intake connect to and where is the stock boost sensor located and mounted?
--please help cant seem to find it in the chilton manual.
The stock boost sensor it attatced on the frame rail just below the intake tube. One vacuum line goes to the sensor, one goes to the pcv valve, and I believe the third lime may go to the charcoal canister or some emissions related part? Someone back me up on this. Oh, you also do not need the stock boost sensor if you have an aftermarket boost controller.
