EGR selanoid CON.
lilpastrana
53
Oct 30, 2005
centuria, Wisconsin
OK, so i blocked of the EGR valve totally, put a peice of sheet metal blocked it off, car still jerks, but is like a studder very quick, and the boost gauge will go to just before 14 on the stock boost gauge, and b4 i blocked the egr valve it would go right all the way to 14... It still idles low. Somthin is telling somthin in the car to put to much gas into the cylinders and it cant burn all of the gas, There is so much carbon everywhere, like in the EGR valve carbon build up in there, on my rear bumped above the exhaust, carbon. I need somemore in put please, Car studders only when under pressure w/ the boost. Run great when no boost pressure, IT sucks gas horribley also..help
1991 plymouth laser 2.0 turbo
