Benag
- 51
- Apr 13, 2005
Atlanta,
Georgia
My car did boost fine despite the fact that it wouldn't boost past 14 psi. I though it was a boost leak (ordered some intake gaskets) but now I think the problem might have been the turbo. This is why:
Does this mean the turbo finally died? And is the turbo probably my only problem? Hope this isn't too much reading.
- For the longest time there has been a slight grinding noise when I boost when the car is cold (I suppose this is the wheel hitting the housing in the turbo). I never though much of it.
- Then, a lot of thick white smoke when I'm under boost. This goes on about two days before it happens (which was last night).
- Almost home and I decide to do a 0-60 run. About to shift to second when the car kicks back and I let off the gas. Then try to boost again but it won't go past 0 psi. Car still seems to run fine though, despite a shitload of smoke now.
- This morning I took the plug off the compressor housing and oil drips out. Took off the intake pipe and oil is setting in the turbo inlet.
- Shook the compressor wheel and it is really wobbly. Probably a half-inch of play.
