dsm4life
- 1,323
- 3
- Sep 24, 2002
Philadelphia,
Pennsylvania
Ok my idle jumps up down sometimes it stalls. Ok i did boost leak test and i fix some small problems. My VAC reads 17-18 which is good. Still does it. I redid my power wire , still does it. Ok so i went snooping even more. I found that if i adjust this screw by turning the nut and pulling the cable then i can get it to a decent idle BUT after a few pulls and such the idle gets out of wack and i have to adjust it again and again to keep it at 700-800. What could be causing this ?
Picture shows nut i am adjusting. Also , that little thingy (tech term) under the gas petal broke so the petal can go to the floor would this have caused this ???
