zrk666
- 144
- May 13, 2004
louisville,
Kentucky
my profile is up to date! i was getting on my car so i could run 15psi becuase i had it set for 10. i was using a different boost controller before runing 10 but when i switched it would go to 15 the drop off to 11-12 psi. the drop would occur when the car hit 15 and then a second or less it would then drop. my question is that the wastegate is to big, or can it be the MBC?
i havedone booost leak test- nothing massive to where it wuoldnt drop that much.
i didnt blow any hooses or short anything out it just wouldnt hol 15psi.
Either you have leaks or you don't, if you know you have leaks, fix them. How much pressure and for how long was the system holding during the pressure test?
