sYnOnYx
- 270
- 1
- Jan 24, 2005
Las Vegas,
Nevada
ok , so yesterday i decided to run open downpipe , car ran great all day long , boosted perfectly ! i havent had one problem with this car since i got it. i had the mbc set to 15psi like usual on 91 octane and ran great all day , so i was a block away from home and all of a sudden the car felt like it was misfiring, so i thought ok , a plug wire must have came loose, pulled over and nope , but the top screw of the mbc was missing , as well as the ball and spring ,( its came loose before ) and im pretty sure i never over boosted it all night long( cuz if no vaccum pressure is going to the wastegate it wont open and let exhaust out right ? ), as i watched the gauge closely like usual.......
so , when i rev it in neutral , instead of vaccum going up, it goes up a lil then goes back down , when i drive , it goes to a lil above 0psi and thats it. i dont hear the turbo spooling whatso ever , i checked the turbo , and non shaft play and spun freely , im not blowing white smoke at all...... or any smoke for that matter, i went and re-hooked up the vaccum line for boost control to the stock way.......... still nothing. i checked the plugs to see if maybe they had oil on em, nothing , checked the uppipe , and no oil at all either in the pipe looked very clean in the throttle body.
so now im stumped. i got this car from an older woman, in perfect shape , and in stock form.
i really have no other means of transportation , and im currently outta work so a new 16g turbo is outta the question...... for the time being.
thus building no boost.
