boostedgst2984
- 210
- 4
- May 5, 2004
pasadena,
Maryland
Here we go, ok my car goes there about a month ago for an idle problem and a clutch slave cylindr problem. before it went there it ran fine except for an idle problem and a clutch slave cyl problem that i knew was leaking then problems just all multiplied out and everything broke clutch just gave up and thier was no pressure in the line at all when we tried to bleed it.
i have a 6bolt and i didnt have time to deal with the problem because i was still in college at the time so i just had it towed to ======= to have everythign fixed at once and they replace the clutch slave cyl and said the clutch is fine it shifts fine in all the gears but grindes a little bit in 3rd but that was because the master is leaking a little bit, so i said ok ill replace that and they half fix the idle problem saying it needs a inake mani gasket. so i go to pick up the car this past tuesday and i pay for everythign and i go to drive the car home and the car wont even go into gear, engine starts clutch feels wierd. So i start car and try to put it in gear and it grinds like it doesnt want to go in gear so im liek what the hell. So i go back and tell them and they said it needs a mastar as well and im like well u said it was drivable just grinds a little in 3rd and blah blah bull shit from them saying that the car has never been driven,so im just like replace the master cyl. They call me up thrusday and said that they replaced it and it still didnt help that much and said they droped the oil pan and measured the thrust bearings and that its past service limits and the engine has crank walk and im like wtf it came there with no crank walk. and it leaves with it and i get the car towed home yesterday and i fiddle with it today. I look at the oil pan bolts and thier all gressy and grimy like they were before the car went to them so they lied about dropping the oil pan. I show my dad whats going on and i go to push the clutch in so he can see the slave cyl move and i go to push it and all you hear is snap and the clutch fork snaps on the thick end and before it snaped it felt like something was holding the clutch fork up like u couldnt push it to the floor. I dont know what to think hear. Extreme motor sports has lied to me on 2 occasions The motor and clutch comonents have 15K on them. What do u all think
Thanks
Dan
Thanks
Dan
