- 466
- 1
- Mar 26, 2004
Spokane,
Washington
Ok, so I have had a stuttering problem for about 9 months. I bought the car with this problem. It was stock when I started diagnosing/replacing, and I added all mods and had no real change.
Aaaanyhow. I think I have a hint.
I went to the track last night, and after boosting a lot and such, it was still stuttering.
On my way home, my car made a loud POP after I went WOT. I killed the engine immediately thinking timing belt.
I popped the hood and noticed the spark plug wire on #1 was not on tightly. I put it back on and drove again... it still stuttered. I went WOT, it popped off again. Aaaanyhow. There is also OIL in the valve cover area, and i can't get the plug wire to stop popping off. I searched, and it seems most people who have spark plug wires pop off have not finished the thread by telling what the issue was. I need some advice here. I think I will get a new valve cover gasket, spark plug seals, and the halfmoon seal. Think this will fix my issue a bit? Could this be the culprit behind my car's stuttering?
Thanks all
I popped the hood and noticed the spark plug wire on #1 was not on tightly. I put it back on and drove again... it still stuttered. I went WOT, it popped off again. Aaaanyhow. There is also OIL in the valve cover area, and i can't get the plug wire to stop popping off. I searched, and it seems most people who have spark plug wires pop off have not finished the thread by telling what the issue was. I need some advice here. I think I will get a new valve cover gasket, spark plug seals, and the halfmoon seal. Think this will fix my issue a bit? Could this be the culprit behind my car's stuttering?Thanks all
