2nd @ W.O.T. and the car is dead
uni_gst
368
2
Jul 16, 2004
Puerto Rico, Central America
95 GS-T
122,600 miles
Well, I just arrived, took a nice ride on a tow and now im sitting here just thinking about what went wrong with the car.
I was driving since I left my home at normal cruising speed ( 40-50mph ) when I was arriving at my Gf's house I decided to hit the gas a lil just to test the car. ( a road about the lenght of a 1/8 ) So when I did it; 1st was awesome, then shifted to 2nd, and right there, bout 2 secs after I did so or about 4.5k rpms. I head like a small bang on my engine and it died.
I could feel the engine when it stopped working, then followed by a hard ticking noise coming from where the timing belt is located (like a "clank clank clank"). My rev's and speed went down, even with the car still moving and everything lit on my gauges.
After that the car went to a stop. I walked out of the car to see if there was anything out of place but everything was ok. So I tried firing the car... no response, not even the sound of a starting engine, just the plain sound of something spinning inside ( starter ?? )
After that and the tow trip, I checked my timing belt, and it seems like its not broken, I mean its tight and where it should be.
My timing belt was replaced at about 115-116k miles & yesterday I did an oil & filter change.
So... my engine is blown ? :confused:
Take off your upper timing belt cover (if you have one) then take a ratchet and spin the crank pulley until the little mark on the outer most edge hits the T (on the lower timing cover). Then look at your cam sprockets, both cam knobs should be facing up 12:00. If they are off then you jumped timing and your valves are bent.
UPDATE:
I fixed the car about 2 weeks ago, but didn't had time to get back with the results.
It was the balance shaft belt that broke and somehow the car bent all of the 8 valves next to the intake manifold ( Sorry I can't name it correctly, im an ESL )
So I got another head and bought the balance shaft belt, and put the car back in time.
Thx !
