IC97TalonTSiAwd
- Feb 27, 2004
Sandpoint,
Idaho
Hi All,
I have a problem that I can't seem to find a hint on while searching. Background: Engine Rebuild ~7000 miles ago with head reworked. Previous owner had no respect. Immediately after rebuild car would not start. After tracking thorugh many ideas the cam sensor fell into primary slot. After replacing car ran well until now. A footnote: Found an Accel Thundersport wire was causing cylinder 1 misfire under mod accelleration. Found to be a bad wire, replaced, issue subsided. Finally we get to current problem.. While driving around pulled a CEL and car seemed to drop to barely running. Pulled over and revved it, car idled up again correctly. Went home quickly. Next am started fine. On the way to work same thing occurred, but could not get it to idle correctly. Called tow truck and then get it home. Problem continued. CEL code P 300 - "Random Cylinder Misfire". Reset and (car cold) started fine and idled up. After warming to temp it began with the same problem. So I checked wires again, all good, just to be safe tried a new set. Continued. Well I figured it may be cam sensor again. Just for giggles I replaced it with a new one to no avail. Car continues to pull CEL after reset. I am going to check spark plugs, gap, and ensure getting spark, but any other suggestions? This problem only seems to crop up under operating temperature. Thanks for ideas,
Steve
Steve
