97' TSI shift issue
Posted by 962ndgen, Oct 20, 2013
Please Support Miller Import Parts
  1. 962ndgen
    962ndgen Proven Member
    47
    Joined Dec 5, 2012
    Charlottesville, Virginia
    Ok so here it goes, I swapped a manual trans in my talon now it will go in reverse and second but pops out of reverse after a few feet and will rarely go in second, I'm thinking its my linkages because in the neutral position it sits pretty close to my dash sound right?
    Log in/Register to remove ads
  2. DSMjunkieNH
    DSMjunkieNH Proven Member
    50
    Joined Mar 20, 2013
    rochester, New Hampshire
    Check your linkage, remove your center in your car see if everything is hooked up properly and everything. Have a friend get in the front and wiggle the shifter and put it in gear with the car off and see what happens up front.
    Loading...
  3. noobin it
    noobin it Probationary Member
    5
    Joined Oct 14, 2013
    Chicago, Illinois
    If all appears to be working right and the gears engage properly, the problem might lie in your trans. Does second engage smoothly when driving? Is there any specific thing that will make either gear pop out?
  4. iugrad92turbo
    iugrad92turbo Proven Member
    10,215
    254
    Joined May 22, 2007
    Kalamazoo, Michigan
    Sounds like a internal problem, with bad gears.
    My DSM:
    Loading...
  5. 962ndgen
    47
    Joined Dec 5, 2012
    Thanks for all the feed back first off!
    I'm about 97-98% positive theres nothing internal going on it goes in 2nd and reverse "stand still" smooth but once I'm moving and try to put it in 2nd it will engage then pop out sometimes pop out and make a grinding noise afterwards it acts like its not going fully into gear at times.. Do 2G's have trans detents? The part that holds a trans in gear?
  6. johnson365
    johnson365 Probationary Member
    Joined Oct 11, 2013
    sevierville, Tennessee
    yes they have dtents if they are installed incorrectly or missing it will pop out of gear mine did the same not to long ago, i also had syncros bad too
  7. 962ndgen
    47
    Joined Dec 5, 2012
    Ok I might be pulling the trans out again after all LOL thats the risk you take in buying a used parts car I guess..
  8. blitzed97
    blitzed97 Proven Member
    50
    Joined Aug 15, 2003
    i now own this talon and still havent figured out whats wrong with it! any other ideas???
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
