small oil leaks
dsm dominator
47
Jul 18, 2004
guelph,
i have two small oil leaks
and my o my have i searched, but to no real prevail
my 2 leaks are from the banjo bolt from the top of the turbo (closest to the inlet)
and from the exhaust manifold (this one i cant dfind a damn thread on, what causes this?)
now for the banjo bolt should i pull the lines and clean them (feed and return), if so, how "committed" is this job, could a clogged line be the culprit? what else should i look for?
thanks for the help
--scott
o and by the by, i received my dsmtuners sticker today, i definetly recommend them they look great!
yes the dsm stickers r cool...has for the leak on the turbo you need to change the copper gasket it could be that it came loose so check and as for the leak on the exhaust manifold you need to change the studs and nut goin into your head.
