InCoGNiTo
- 59
- May 7, 2003
Talon died tonight and wont go, ill try my best to explain what happened and maybe someone can give me some help or suggestions to the problem.
went to head out tonight, car was working fine.
driving for about 45 minutes, all was good. no problems at all.
I went to turn around in a parking lot and as I exited the lot I decided to come out a little hard.
I went to WOT and full boost in 1st gear, I went to shift at 5000-5500 Rpm and thats when it died..
when I got to second gear the car wasn't running.
so I pull over with the car still off and attempt to start it and nothing.
So I check everything I can, full tank of gas, nothing mission or visibly damaged under the hood, proper fluid levels and so on.
So I go and try to start it again, the car rolls over fine, no knocking or "bad" noises, it sounds normal when attempting to start.
so when a friend got there to help me we checked a few more things, hauled the timing belt cover off (I was in fear of a snapped belt), belt looks fine, seemed a little slack to me but he said it was normal ?.
next we hauled off the inlet pipe for the turbo, turbo looked ok, spins freely and so on.
so we put everything back on and check it over again, oil level is good, lots of gas and so on.
go to start it again and still just rolled over.
after that, I left the key in the on position and checked under the hood again, this is when we noticed a constant "ticking, clicking noise", seems to be coming from the intake manifold area, the upper portion of it, close to the fire wall.
there is a few sensors in the area, I'm just not sure which they are.
turn the key off and the noise goes away.
back to the on position and it came back, didn't seem as loud the next time we did it tho.
I always heard the ticking from inside the car each time i started it, actually had it checked out one time, mechanics told me it was just relays "turning on" and so on, they said its normal.
it just didn't sound right to me, or maybe it was just louder hearing them from the engine bay and not inside the car.
I checked what I could on the side of the road, she wouldn't go and I had to get towed home .
When the car died I never heard a thing, I had the radio on a bit but not loud enough so i couldn't hear what was going on around me, heard no bang, no boom or no snaps, no noises at all to indicate a major breakdown.
one other thing and maybe an important key is, by looking at the boost gauge while attempting to start it, it doesn't seem to be building vacuum ?
and I'm sure it always did and there supposed to ?
I don't really look at it when starting the car, but I did glance at it tonight and it didn't seem to be making vacuum when starting, should it ?
if they do and mines not what does that point to ?
With no sign of a snapped T belt or blown turbo and or anything else majorly wrong I attempted to start it again when I got it home, still nothing oviously...
its just rolling over, its not even attempting to start itself.
almost as if there was no spark or no fuel ? what it seems like anyways.
But they are 2 things I didn't check yet.
sorry for the long speech, just trying to make it as accurate as possible to help narrow it down.
anyone have any ideas or suggestions to help me get her going again ?
_________________
1997 Talon TSi AWD
_________________
1997 Talon TSi AWD
I was looking at the braket it sits on and was thinking of putting a hole in it and running a zip tie around the whole thing....I havent gotten to it yet. If you Figure Something out let me know so i can do it.....damn snow is killing me
anywas glad I could Help.
