WhiteCloud
- 471
- Mar 16, 2004
California
My car is burning a bit of oil. Not a trailing cloud of blue smoke when I drive, but sometimes a puff comes out when I start the car, or when I give it a quick rev in neutral, or taking off from a stop. When I took the plugs out to do the test, there was a bit of oil on the plugs, especially in cylinder 1.
So, I did a compression test--180, 170, 175, 180. Seems pretty good to me for a car with 85k miles, considering spec is 178. Do you all think I can rule out rings and valve seals with this compresssion?
I'm thinking PCV valve--should I just replace it, or is there something I can check to see if it is functioning properly or not? Any tips on replacing it, or is it a simple unbolt, then bolt-on trick?
