VIPERBLUELX
- Dec 3, 2004
Ringgold,
Georgia
I installed a MBC like the one pictured and for some reason it won't add any boost. When I got the car it made 10psi with a peak around 11psi occasionally. I installed the boost controller with the bolt almost all the way unscrewed and the car made 8psi so I started turning it in to dial in more boost and I ended up with the bolt turned all the way in so that valve is basically shut off and I'm still only making 10-11psi. Do I have a faulty MBC?
