Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum > Problem Diagnosis
Problem Diagnosis Can't figure out the problem? Does the question not fit in one of the other tech forums? New Members can post here.
Reply
LinkBack Thread Tools
Old 11-20-2004, 11:16 AM   #1 (permalink)
Proven Member
Region: Southeast
Classifieds Rating: (1)
Reputation: Fmstrat is an unknown
95 EPROM ECU wont crank in 97
I've got a 97 Spyder GST (manual). I'm about to do an injector and dsmchip upgrade, so I got an EPROM ECU from a 95 talon AWD (automatic) off partstrader. I wanted to test the ECU out to ensure it works properly before I socket the EPROM.
Swapped my ECU for the 95 ECU, and the car won't crank. It made a wierd "pop" sound the first time, so I was worried, but I tried again and it just hesitates. I think the pop might have just been backfire and I wasn't paying attention. Anyways, I swap back to my 97 ECU and she fires up and drives fine again.
Any ideas why the 95 wouldn't work? I opened it up, and all the caps look good.
Offline
Related Auctions
Sponsored Links
Old 11-20-2004, 11:55 AM   #2 (permalink)
Proven Member
Region: Southeast
So a friend had a theory about this. We know that automatic vs manual and AWD vs FWD doesn't matter once you chip the ECU, but does it matter when using it in stock form? I.E. is the automatic ECU trying to control a transmission that isn't there?
Offline
Old 11-20-2004, 01:08 PM   #3 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: cuong1106 is an unknown
swap the spark plug wires around. from 1 to 4 and 2 to 3. switch the two outside wires around and switch the two inside wires around it should fire right up.
Offline
Old 11-20-2004, 06:39 PM   #4 (permalink)
Proven Member
Region: Southeast
Really?? That just sounds.. odd. Why were they reversed for this ECU?
Offline
Old 11-20-2004, 10:19 PM   #5 (permalink)
Proven Member
Reputation: Mitsumanny is an unknown
Firing order is reversed on the 95 eprom and the 97 ecu's. I had that problem when i installed a 95 ecu for the dsm chip. try it out.
Offline
[posts] Reply With Quote
Old 11-21-2004, 03:59 AM   #6 (permalink)
Proven Member
tsunari's Avatar
Region: Mid Atlantic
Classifieds Rating: (13)
Reputation: tsunari is pretty helpful and trustworthytsunari is pretty helpful and trustworthy
Quote:
I agree . . . - give it a try
____________________________
tsunari
-'97 GST -
Offline
Old 11-21-2004, 06:34 AM   #7 (permalink)
Proven Member
Reputation: Hummer is an unknown
Quote:
AT has its own computer(TCM)! It matters only when using a 1G AT ECU in a 1G MT car as the 1G AT ECU is mapped for 390cc injectors. 95 AT ECU will work find in a 97 MT car, just switch the plug wires. Do your home work?
Bob
Offline
Old 11-21-2004, 06:45 AM   #8 (permalink)
Proven Member
Reputation: lowridin2g is an unknown
my stage 3 chip is on its way from jeff. i also got a 95 ecu from him. he did the cas inversion for me so there will be no rewiring the injector's
Offline
Old 11-21-2004, 06:55 AM   #9 (permalink)
DSM Wiseman
dave99gst's Avatar
Classifieds Rating: (29)
"The '95-'96 style Cam Angle Sensor (CAS) sends out a signal that's electrically "inverted" from other DSM cam sensors (1G or '97+ style). When you put a '95 ECU into a car with a non-95 CAS, the ECU ends up swapping the firing order of the injectors"
"We can't control spark firing order in the EPROM at crank time. So even with CAS inversion, you still have to swap plug wire 1 with 2 and 3 with 4"
Quote from dsmlink.com
http://dsmlink.com/faq.html#cas
Offline
Old 11-21-2004, 06:58 AM   #10 (permalink)
Proven Member
ahh, no kidding. its a good thing i got this cleared up before i installed the ecu and chip and then jumped the gun cursing and kicking and punching cause my new ecu and chip doesnt work
Offline
Old 11-22-2004, 07:29 AM   #11 (permalink)
Proven Member
Region: Southeast
OK, makes sense now. As for "doing my homework," that's what I'm doing now. With 30 billion posts out there, its hard to find exactly what you're looking for sometimes. Sorry if this has been asked before and I missed it.
Now, I understand all of the above, but if the CAS has to be inverted, and I'm using a stock 95 ECU, would that mean I only need to swap plug wires, or do something with the injectors (harness) as well?
dave99 - Found that quote on dsmlink's site. From the rest of it: "In most cases, this produces very little noticeable difference in drive quality. But we offer the option to invert the CAS signal anyway just in case." It appears as if the answer to my above question is "no".
Thanks for the help everyone. I'll swap the wires and see what happens.
Offline
Old 11-22-2004, 08:11 AM   #12 (permalink)
Proven Member
Reputation: PaleDSM is more helpful than not
Without swapping the injectors as well some people get constant random misfire codes thrown. Most people swap them for better drivability.
Offline
Old 11-22-2004, 09:31 AM   #13 (permalink)
Proven Member
Region: Southeast
OK, so is it just as simple as swapping the plugs on the injectors to match up with the spark plug wires?
Offline
Old 01-11-2005, 02:45 AM   #14 (permalink)
Proven Member
Region: SoCal
Reputation: tt281gt is an unknown
BUMP
Offline
Old 07-20-2008, 04:59 PM   #15 (permalink)
Proven Member
Region: Southwest
Reputation: GST98BIG16G is more helpful than not
Cop
How about COP setup?
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.20606995 seconds (83.78% PHP - 16.22% MySQL) with 9 queries
