Need new hubs for 1992 awd eclipse
2.4 turbo Hyped
575
3
Jan 6, 2004
Portland, Oregon
I got new wheel bearings but come to find out the hubs that get pressed into the bearings are bad. I cant find a website that sells just the hubs. When I say hub I am talking about the part that the lug studs press into. Does anyone know of a website that one is able to enter mitsu part numbers into and make a purchase right there?? Please help a dsmer out :)
How bad does Mitsu rape you for just the hub itself? You could just give them the part number and ask, maybe it won't be too bad. I think they wanted like $130ish around here for the hub and wheel bearings for a 2g AWD, so maybe half of that?
Yea, I wouldnt' put junkyard hubs/bearings on my car either...junkyard is great for some parts, but sometimes you just need to bite the bullet and get new stuff.
2.4 turbo Hyped said:
I dont put junk back on when I just took junk off.
LOL, that's unfortunate. I bought a passenger side knuckle/hub assembly for 15$ from the junkyard. Wheel bearing is fine and rides perfectly. Does your car have abs?
There are ways to determine if the used part is trashed or usable. You just have to exert alittle effort and common sense in determining which will work for you. But if you got money to throw around, screw it, and buy new stuff.
mike :dsm:
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
