Jackson
- 98
- 1
- Jan 10, 2003
Okay, here is my specific problem. My car cranks but won't turn over. My battery is kinda pooched, but I charge it up and I get about 4 good tries before it's dead (I have a volt meter hooked up).
Is this the problem due to a dead alternator killing my battery in the process? I am running a VERY demanding system (800 RMS @ 4 ohms + ps2 and screens) or could this be something else?
Yet even after a good charging, my car just won't start. o2 sensor other than that its kinda old. My AEM reads the TPS fine so I know that one is good. Any ideas? Cause it will randomly start from time to time with the stock ECU. ( very spuratically)
) and have someone crank on it. If you feel a little bit of sucking, then you have compression. Try that with all four cylinders. But i would also user a tester, to see if the compression is about equal between all four.
