Need some help asap. diagrams and pics please Apexi safc & AVCR
SUPERMAC
46
Feb 17, 2004
Vancouver, Washington
HEy i need to know if anyone has any drawing or diagrams or pictured of how there setup is done. i need the following:
Apexi safc & AVCR
t3/t4 turbo
External 38mm wastegate
550cc injectors
a/f & and boost gauges
what i basicaly need to do is compare my setup to everyone elses. if you have any of these please post up how you installed it and any pics you can. i have mine all installed but the car doest run very well and its just bugging me. so i want to check and make sure they are setup right.
thanks,
chris
sorry, guess i could have been a bit more specific. :)
whats its doing is mainly not revving up until about 4K rpm, and then once it hits you can tell its there and good, but it stutters and popes a bit and wont accelerate. it feels kinda like spark blowout or a horrible boost leak, but i no its not boost leak, i have tested it. and i know its not spark blow out cause i have re-gapped NGK plugs. the only other thing i can think of is that maybe my boost hoses or something is off for my boost controller an the area above the intake plenum. i attached a pic of my setup, please look over the routing of everything to make sure it looks right. if anything seems off let me know.
thanks a lot,
chris
Have you actually programmed your fuel curves into the SAFC yet?
yeah i did some base settings of -20 accross the board. and i set the hi settings to -15 accross. just to get it running. it seems to idle just fine. its only when i got to accelerate when it starts to run badly.
thanks,
chris
yeah i am sure it needs some more tuning. but i just wanted to make sure all my hoses and everything were routed right. i think they are pretty good, but im no expert so i just wanted some other opinions.
thanks,
chris
yeah i am using a stock FPR,a dn i just swapped out the stock fuel pump cause the one i had bought ended up not being the correct one for my car. so it wouldnt fit.
thanks,
chris
i have one on order actually but it wont be here for another few days.
thanks,
chris
