Please tell me the head gasket still sealed
1993TalonTsiAWD
339
6
Jan 26, 2003
Glendale Heights, Illinois
I put the head on my new project, a 1990 eclipse GSX, and I forgot to take out the intake bolts on the back of the intake, please tell me the head gasket still seated, and do I need to bolt it down in back, or will I be fine. If I have to take the head off I will be pissed since a new HG is about 50.
thanks Derek
PS can someone tell me what size of bolts I need for the t-stat housing that is on top.
the one that has the cap, there is tow bolts and I lost them
thanks Derek
If it's unclear I for got the bolts were in and bolted down the head with them against the bracket on the back
thanks Derek
just make sure that the bracket did not stop the head from going all the way down, if it did and you have not run the engine just un blot the bracket and finish settng the head.
the head is all the way down on all sides so I should be ok?? at least I hopw so. It torqued down to 80 with no prob's on the ARP's
thanks Derek
