The infamous noise of bolt that came out while I was driving
L2RTSiAWD
Honorary Moderator
11,533
29
Apr 8, 2002
Chandler, Arizona
It happened last night on the way home.
The idle is still fine, but when I come on to the boost(at part throttle 30-40%) it's either pulling timing or bogging down like it's rich or lean.
The mods are:
walbro 255
1g spoolinup AFPR on 1g rail.
B&M fuel pressure gauge on fuel filter
Stock 450cc injectors
S-AFC
T-25
AGP-FMIC
turboback exhaust
I was thinking about trying to mess with the afc to see if it would bog less if I make it richer or leaner.
I'm just not sure what could have came off that would only affect boost performance but idle is still fine.
I didn't think to check that. I'll look at later on my break.
thanks Brian.
I was under the impression a boost leak would pull performance but not timing
maybe try lean/richening it +-5% to see if it helps...
Well the BISS is still there and I thought maybe the adjusting nut on the AFPR came off but that was still there also.
When I can actually drive it after work in I will try to lean/richen to see if I can get it to go away.
IC couplers are good to go, John?
A quick check this morning said yes and the fact it still idles fine says yes but I will check again in the next 30min.
I only have 4 couplers and they are all good.
Another thing I didn't think off until I sat down at my desk was in my UICP close to the throttle body I have a 1/8 inch NPT plug that I used to plug a hole I had drilled for when I had my propane kit. I'll have to see if maybe that backed out.
I have to lean out the afc 5-10% for it to clear it up a little which led me to believe the MAS is reading the air and adding fuel but it's escaping before getting in the motor so it's running to rich.
Time for a leak test. :p
As I suspected the 1/8 NPT plug backed out so there is now an 1/8 hole in my UICP air is escaping from...LOL
This time I will locktite the son-of-a-bi*** :D
