DSMhelex
- 445
- 2
- Jan 8, 2003
Du Bois,
Pennsylvania
ok
ive read a couple threads about a similar problem to mine, but i would like some of you guys to verify that i am correct.
Last sunday me and a couple friends went on a trip and we were doing some crazy interstate driving (80mph+)... well anyway, when i came back to my hometown i noticed a faint whining/jet engine sound. I didnt think too much of it, but as the week went on, it seemed to get progressively worse. First i thought it was my tranny, so i flushed it and put new tranny fluid in it and that was not it. It was hard to hear where it was coming from. Today i got the oil changed just to be sure that wasnt it because i went over my recommended change by a few thousand. Didnt fix it. Just as an experiment i started putting it to WOT to see what boost i would hit and sure enough i only hit 7psi (i usually spike 16 and hold 12).... i did it a second time and i only got 5psi.... and the 3rd i only got 3-4psi. I figured i had a leak. Checked everything and no leaks. Right now, My car is making a VERY loud sound, almost like a jet engine powering up. This is syncronized with the hiss of turbo/boost. I can only hit 3psi now and my greddy bov no longer blows off (not enough psi?), and it seems to be smoking a little bit more than usual (turbo going?). Also, when i rev my car in neutral/park, around 3,000rpms i get a little ticking noise (shaft play?). Im thinking this is a turbo problem. Im still running the stock t-25 and i run stock boost (stock intercooler too) with a full 3" exhaust. A few of my friends (myself included) think its a little wierd that a turbo on a 34000 mile car would go so fast. Correct me if im wrong, but its the turbo going? Any input would be appreciated. thanks.
