BombNastyGST
- May 12, 2002
Leominster,
Massachusetts
I bought a set of Iridiums and installed them 3 weeks ago, and the car has never run better, until tonite. I go to give it gas in 3rd and it just starts misfiring....so i put it in neutral and coast, then try it again, still doing it. Pull out the pocketlogger and it says "cylinder 3 misfire detected". Car starts running fine, i pull over, clear the code, drive home. Check the wire, fine, connected on both ends. Now i run 15 psi on the street with 93 octane. Should i be running a step colder plug? Is that what caused my misfiring?
