Logue
- 408
- 6
- Sep 27, 2003
Tuckerton,
New Jersey
i'm logging .96v on my logger on a 3rd gear pull at 13psi with a b16g, 190lph and 550cc.
I've done some searching but can't really find a lot. Figured i would ask you guys.
I only ask becuase my car has been backfiring in 2nd gear and above at about 4,500 -5,000rpm and above. Its usually just one big backfire then power resumes then if i hold again becuase i'm mad becuase it backfired it will do it again a couple seconds later. i don't know what the 02 were with no injectors or pump. but it did backfire.
Is .96v enough to make a rich condition and backfire. The backfire started when i installed my big16g. i thought it was fuel cut(never knew what it felt like just assumed). So i bought 550cc, 190lph, and safcII, installed both pump and injectors went for a ride and it did it again. I installed the SafcII, but i'm little scared to mess with it becuase i don't want to mess anything up more. i got on it one time in 2nd real hard backfired, bucked and the check engine light came on. It said, turbo wastegate selonoid malfunction. that has happened twice over the course of 2 weeks. I have a mbc hooked up to 13 pounds. i bought new ngk bpr7es plugs and magnacore 8.5 wires, did a leak test found a leak out of the lower intercooler pipe fixed it. Still backfires. I'm going to do a ignition coil test tommorrow, and power transitor test, also maybe i'll try to find a new crank angle sensor. I have a 6 bolt head, intake, and tb on a rebuilt 7 bolt block. ummmm yahh so if you guys have anything else to add or yell at me for please do it. becuease kids in my town want to race and i don't want to dissappoint all of my push rod engine owning friends
JJ
JJ
