Ok I tried myself...I now need a wiseman's help...
DSMeclipse4G63
1,595
Mar 10, 2003
columbia, Maryland
Ok heres the problem, I press the gas pedal to accelerate(any form of acceleration counts for this problem) I hear the turbo start to spool and check my gauge it reads normal linear boost, the engine revs ...but the engine bogs down and barley accelerates(not a clutch slip). The problem got worse when I put my accel plug wires on about 1 1/2 years ago. So I assumed it was a ignition problem, I tested the coil and found the primary side had too much resistance so I replced it with a good coil and still boggs down. Now the problem only happens once in a blue moon(not very common but I still wanna fix it). I need to know what to look for as I am completely lost, I am ordering my datalogger tonight, so if there are and pids(datastream) I should look at please tell me.
lost and confused dsm'er
ok back from the beach...I have a new fuel filter, pump, ignition wires(accel), and plugs(bpr7e). I had this same problem with my stock bov, my 1g(perfect conditon)bov, and now my greddy type s. I am lost I will check ignition timing when I get my datalogger crap in. But anyone have any other ides??
Andrew
