5PointOh
- Mar 21, 2004
Columbus,
Ohio
Howdy, I bought my DSM a few months ago with a bad timing belt and some bent valves. After a few days, a headswap and new timing tensioners, etc. We got it running, however, it started knocking. Checked the oil and there was none in the crankcase, but it only ran for maybe a minute... I put some 10/30 in it and it still did it. Oil should have quieted it down a little bit, but didn't. Then it konked out and died and I gave up. However, right afterwards, literally minutes, I tried turning it by hand with a ratchet and it was normal, but no compression. The oil pressure seems fine, at least on the guage.
My question is...
Is it possible that since it was my first time doing the timing belt and not using the special tool it was off enough to cause a severe knock? The engine was rocking slightly with each knock. It sounded external, but you could feel it if you touched the engine.
Or, the bad scenario, a rod bearing( or four) are toast?
Right now, it's 120 miles away at my parents, so I won't be able to get you immediate answers... However, I DID buy the special tool to set the tension($15 online, I got two), an I-beam style torque wrench, stuff to check/rebuild the oil pump(I'll probably get a new oil pump and keep the seals as spares...), I got a used high mileage head on ebay and had a local shop do a valve job, and deck the head for flatness and to take a scratch out. I also got a balance shaft delete kit to do if everything checks out when I'm under there checking the rod bearings. Luckily, my little sister's graduation party is a week away so I'll be dragging it home...
My question is...
- TOAST - & Toasted Balance Shaft Bearings too..
