TalonspoolAWD
- 156
- Jul 9, 2003
I got a t3/t4 from ebay for $300 BRAND NEW. I also got the bullseye housing to make it a direct bolt on a a oil install kit from diamond star motorsports. Here is the problem. I got the whole thing on a i went to boost it and herd this scraping so went home and looked and the compressor wheels were scraping. Plus the car never made hardly any power with this turbo. I took the oil line off and there was oil. So i thought that maybe i should try it from the head to feed the oul in the turbo. I drove it for a little bit and now the turbo has TONS OF SHAFT PLAY AND NO BOOST AT ALL. ITS BLOWN. Its brand new. I did make sure the car had oil pressure before i started it by pulling the injectors fuse. Now i dont know what to do cause everything seemed good at time of install. Maybe the turbo itself was junk. It is suppose to be BRAND NEW AND DID LOOK IT. It is from E-bay and i thought $300 was sorta cheap for a Stage 3 50trim housing 57trim wheel.
ANYBODY GOT ANY IDEAS CAUSE I AM SO UPSET THAT THE BRAND NEW SETUP IS BLOWN ALREADY
Thanks
Tom
Thanks
Tom
