timstsi
- May 14, 2004
Glendale,
Arizona
Help! I have 90 Talon AWD...
I change a bad head gasket and reassembled my car and now its running really rich (black smoke). My check engine light is also on...I check the ECU codes and they all point to a bad Air Flow Meter. I changed the Meter and I have the same problem. In the past I had problems with my Inginition Power Transistor...could this be causing the problem? Are there some other things I sould be checking??
