OverBoost
- Mar 29, 2002
Already did a search on this and didn't really find any info on it. Well I have a 92 Talon TSI AWD. It has automatic seatbelts. What happens with it is when I start the car and the seat belt goes back, this is with the door closed, it gets to the end then comes up a little then back down. It keeps doing this. Up and down up and down. You guys get the idea. It gets really irritating
and not to mention it's not safe when there is a passenger in the seat. Sometimes it will not do it and other times it will. Other times it will not do it then when I step on the brake it does it. It will stop certain times if I open and close the door or shut the car off then back on.
I was wondering if any of you guy have ran into this problem before? Is there any kind of sensor, fuse, or wiring that controls the seat belts. Any of you guys have any ideas on this. Any help would be appreciated. Thanks for and info anyone can provide.
and not to mention it's not safe when there is a passenger in the seat. Sometimes it will not do it and other times it will. Other times it will not do it then when I step on the brake it does it. It will stop certain times if I open and close the door or shut the car off then back on.I was wondering if any of you guy have ran into this problem before? Is there any kind of sensor, fuse, or wiring that controls the seat belts. Any of you guys have any ideas on this. Any help would be appreciated. Thanks for and info anyone can provide.
