tsidrift1
- 819
- 5
- May 12, 2004
Decatur,
Illinois
i have a 92 talon tsi that i am redoing the timing on. i was wondering if the pistons have to be set at top dead center. i have a 1.8 L eclipse that i did the timing on and it had to be set at TDC, but the 2.0 tunrbo has an ignition coil, not the distributer. and when i did the pistons to TDC the iming mark on the crank didn't match up. should i line up the mark on the crank and not worry about TDC? and where would the cams have to be set at on either situation.
