Exhaust Smoke Building Up - Turbo?
Daenon
Jan 6, 2004
Knoxville, Tennessee
When I run it hard and then stop smoke BILLOWS out of the exhaust. If I run it hard enough the smoke can almost cover the whole car. The key is the smoke doesn't come until the car comes to a complete stop, the harder I gun it the more smoke. I'm thinking it's the turbo since it only comes when I drive hard, not rev hard. I dunno the mechanics of turbo so if you guys know/have any idea it'd be appreciated.
Daenon
it is most likely your seals on your turbo. If it only does it when you stop thats sign its your turbo mines doing it now also :( it's cool though cause I'll have either a PTE 50trim or PTE GT32E mmmmmm. hehehe
mith
Yep oil seals on your turbo are shot. It would be a really good idea to check your oil level before you drive it again, since all that smoke is your oil being burnt...
Thanks for the help guys. Yea, I've been checking it before I drive everytime. So can the seals be repaired?
Daenon
Yea I was thinking about grabbing a used big16g and running it on low boost until I can afford an exhaust. Now all I've got to do is find one :(
check the classified section last time I checked (friday) thier was a used 16G with less than 8k miles on it supposedly babied never over 18psi for $400. check it out
mitch
