DSMSimms
- 50
- Jun 20, 2003
Bel Air,
Maryland
i have a 1999 gs with a 420a in it. when i was driving home from work it started to bog pretty bad and then some detination started to happen. i already check all the spark plugs and ignition wires and they appear to be fine. also did a compression test to make sure nothing major was wrong but the numbers from the test are coming up normal. im taking a guess and thinking it is a problem with the distributor but im really not sure. does any one know anything about this or have had the same problem and can tell me how to fix this...thanks for ne help..i really need it
